- junior4096
Data de inscrição : 09/01/2019
DTC Código de erro
9/1/2019, 21:21
Boa noite pessoal. Alguém tem a tabela de DTC código de erro do Jeep Renegade Flex?
- SDKWeb
Data de inscrição : 19/02/2019
Re: DTC Código de erro
20/2/2019, 08:46
Esses códigos estão em inglês,. Caso não entneda, cópia e cola no Google Tradutor que ajuda:
Manufacturer Specific Codes
P1105 Open Or Shorted Condition Detected In The Baro Read Solenoid Control Circuit - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1192 Inlet Air Temp. Circuit Low
P1193 Inlet Air Temp. Circuit High
P1194 Incorrect Or Irrational Performance Has Been Detected For The PWM
P1195 O2 Sensor 1/1 (Bank 1, Sensor 1) Slow During Catalyst Monitor - Read Our Article on Oxygen Sensor Codes For Help With This Jeep Check Engine Light Code
P1196 O2 Sensor 2/1 (Bank 2, Sensor 1) Slow During Catalyst Monitor - Read Our Article on Oxygen Sensor Codes For Help With This Jeep Check Engine Light Code
P1197 O2 Sensor 1/2 (Bank 1, Sensor 2) Slow During Catalyst Monitor - Read Our Article on Oxygen Sensor Codes For Help With This Jeep Check Engine Light Code
P1198 Radiator Temperature Sensor Voltage Too High
P1199 Radiator Temperature Sensor Voltage Too Low
P1243 Open Or Shorted Condition Detected In The Turbocharger Surge Valve Solenoid Control - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1280 Open Or Shorted Condition Detected In The Fuel System Relay Control Circuit - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1281 Engine Operating Temp Below Acceptable Range
P1282 Fuel Pump Relay Control Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1283 Idle Select Signal Invalid
P1284 Fuel Injection Pump Battery Voltage Out Of Range
P1285 Fuel Injection Pump Controller Always On
P1286 Accelerator Pedal Position Sensor Supply Voltage Too High
P1287 Fuel Injection Pump Controller Supply Voltage Low
P1288 Intake Manifold Short Runner Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1289 Manifold Tune Valve Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1290 CNG Fuel Pressure Too High
P1291 No Temp Rise Seen From Fuel Heaters
P1292 CNG Pressure Sensor Voltage Too High
P1293 CNG Pressure Sensor Voltage Too Low
P1294 Target Idle Not Reached
P1295 Loss Of 5 Volts To TP Sensor
P1296 Loss Of 5 Volts To MAP Sensor
P1297 No Change In MAP From Start To Run
P1298 Lean Operation At Wide Open Throttle
P1299 Vacuum Leak Found (IAC Fully Seated)
P1388 Auto Shutdown (ASD) Relay Control Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1389 No Auto Shutdown (ASD) Relay Output Voltage At PCM
P1390 Timing Belt Skipped One Tooth Or More
P1391 Intermittent Loss of CMP Or CKP
P1398 PCM Is Unable To Learn The Crankshaft Position Sensor's Signal
P1399 Wait To Start Lamp Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1403 Loss Of 5 Volts To EGR Sensor - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1475 Auxiliary 5 Volt Output Too High
P1476 Too Little Secondary Air
P1477 Too Much Secondary Air
P1478 Battery Temp Sensor Voltage Out Of Limit
P1479 Transmission Fan Relay Circuit Open Or Shorted
P1480 PCV Solenoid Valve Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1480 Open Or Shorted Condition Detected In The Positive Crankcase Ventilation (PCV - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1481 EATX RPM pulse generator signal for misfire detection
P1482 Catalyst Temperature Sensor Circuit Shorted Low
P1483 Catalyst Temperature Sensor Circuit Shorted High
P1484 Catalytic Converter Overheat Detected
P1485 Air Injection Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1486 Evap Leak Monitor Pinched Hose
P1487 Hi Speed Rad Fan CTRL Relay Circuit Open Or Shorted
P1488 Auxiliary 5 Volt Supply Output Too Low
P1489 High Speed Fan CTRL Relay Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1490 Low Speed Fan CTRL Relay Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1491 Radiator Fan Control Relay Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1492 Battery Temperature Sensor Voltage Too High
P1493 Battery Temperature Sensor Voltage Too Low
P1494 Leak Detection Pump Switch or Mechanical Fault
P1495 Leak Detection Pump Solenoid Circuit Open Or Shorted
P1496 5 Volt Supply Output Too Low
P1498 High speed Rad Fan Ground CTRL Rly Circuit
P1499 Open Or Shorted Condition Detected In The Hydraulic Cooling Fan Solenoid Control
P1594 Charging System Voltage Too High
P1595 Speed Control Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1596 Speed Control Switch Always High
P1597 Speed Control Switch Always Low
P1598 A/C Pressure Sensor Voltage Too High
P1599 A/C Pressure Sensor Voltage Too Low
P1602 PCM Not Programmed
P1680 Clutch Released Switch Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1681 No Instrument Panel Cluster CCD/J1850 Messages Received
P1682 Charging System Voltage Too Low
P1683 Speed Control Power Relay Or Speed Control 12 Volt Driver Circuit Open Or Shorted
P1684 Battery Disconnected Within Last 50 Starts
P1685 Skim Invalid Key
P1686 No SKIM Bus Message Received
P1687 No Cluster Bus Message
P1688 Internal Fuel Injection Pump Controller Failure
P1689 No Communication Between ECM & Injection Pump Module
P1690 Fuel Injection Pump CKP Sensor Does Not Agree With ECM CKP Sensor
P1691 Fuel Injection Pump Controller Calibration Failure
P1693 DTC Detected In ECM Or PCM
P1694 No CCD Messages Received From ECM
P1695 No CCD/J185O Message From BCM
P1696 PCM Failure EEPROM Write Denied
P1697 PCM Failure SRI Mile Not Stored
P1698 No CCD Messages Received From PCM
P1699 No CCD/J1850 Messages Received From The Climate Control Module (CCM)
P1719 Skip Shift Solenoid Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1740 TCC Or OD Solenoid Performance
P1756 Governor Pressure Not Equal To Target At 15-20 PSI
P1757 Governor Pressure Above 3 PSI When Request Is 0 PSI
P1762 Governor Pressure Sensor Offset Improper Voltage
P1763 Governor Pressure Sensor Voltage Too High
P1764 Governor Pressure Sensor Voltage Too Low
P1765 Trans 12 Volt Supply Relay Control Circuit Open Or Shorted - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1830 Open Or Shorted Condition Detected In The Clutch Pedal Switch Over-Ride Relay Control - Read Our Article on Automotive Circuit Testing For Help With This Jeep Check Engine Light Code
P1899 Park/Neutral Position Switch Stuck In Park or In Gear
20/2/2019, 09:44
junior4096 escreveu:Boa noite pessoal. Alguém tem a tabela de DTC código de erro do Jeep Renegade Flex?
Junior, no Doutor Carro tem uma bela lista:
https://www.doutorcarro.com.br/tabela-de-codigos-de-erro-dtcs-obd2-significados/
- paulo VR
Idade : 62
22/2/2019, 22:30
E´ necessário um Scanner ou estes trouble codes podem ser mostrados no painel
do próprio carro?
do próprio carro?
24/2/2019, 09:56
paulo VR escreveu:E´ necessário um Scanner ou estes trouble codes podem ser mostrados no painel
do próprio carro?
Só com um scanner.
